serhatakalin
MAC Terminal komutlar? ve kullan?m?
- 26 Ekim 2010, 14:49
Merhaba Arkada?lar,
Terminal kullan?m?na ili?kin konular burdada payla?abiliriz.
serhatakalin
Cevap #1 - 26 Ekim 2010, 20:22
Merhaba Arkada?lar,
?lk kodlar? yaz?yorum.
1) 2D Dock
This quite a popular hack for the people running Leopard and don’t like the 3D feel. It changes the 3D dock to a flat 2D version. To enter copy and past the following code.
defaults write com.apple.dock no-glass -boolean YES
killall Dock
2) Gradient Behind A Stack Item
One of my favourite hacks that enables you to put a small gradient behind an icon. I think this should be enabled by default.
defaults write com.apple.dock mouse-over-hilte-stack -boolean YES
killall Dock
3) Add A Message To The Login Window
This little Terminal command enables you to add a message of your choice to the Login window. Pretty cool and deserved a screenshot if I new how to take on while not logged in. Warning it’s a sudo command which can be dangerous.
sudo defaults write /Library/Preferences/com.apple.loginwindow LoginwindowText "Your Message"
Replace “Your Message” with the message of your choice, don’t make it to long. If you want to revert it do the following.
sudo defaults write /Library/Preferences/com.apple.loginwindow LoginwindowText ""
4) Add An Exposè Button To The Desktop
If you have reconfigured the F9 and F10 keys to something different you may want to use exposè. This hack adds a bigish blue button onto the desktop to enable you to use exposè. Clicking on it shows all the windows from one application (F10 default), option clicking it shows all windows (F9 default).
defaults write com.apple.dock wvous-floater -bool YES
killall Dock
5) Address Book Debug Menu
If you have some trouble with Address Book it may be useful to open up the debug menu as well as this use some of the hidden features. Make sure address book is closed first before applying the code. If you want to revert it remove YES in the string.
defaults write com.apple.addre ssbook ABShowDebugMenu -bool YES
6) Increase Dock Magnification Size
This little hack lets you increase the size of the magnification of the dock icons. Don’t go past 512.
defaults write com.apple.dock largesize -int 512
7) Increase Desktop Icon Size
If you want massive icons on you desktop this little hack lets you increase the icons to 512 pixels x 512 pixels. This is massive, may slow down on older machines. I don’t think it goes larger than 512.
defaults write com.apple.finde r DesktopViewOpti ons -dict IconSize -integer 512
killall Finder
8) Changing the Format Of Screen Shots
If you use the screen shot function, you may want to change the format of the images, this is not easily done normally. Where jpg is in the code you can change this to the format your want, png bmp gif etc. You need to log out and back in again, or restart for the changes to take effect.
defaults write com.apple.scree ncapture type jpg
9) Change The Login Picture
If you get a bored of the space picture used on the login screen, you can change it with this little bit of code. Change the file location in the second half of the string to the exact file location of your chosen picture.
defaults write /Library/Preferences/com.apple.loginwindow DesktopPicture "/System/Library/CoreServices/Finder.app/Contents/Resources/vortex.png"
10) Change The Loading Bar In Safari To A Pie Chart
This is a Safari 3 hack, so it might not work. This changes the blue bar that goes across the address bar into a small blue pie chart. Insert false instead of true to reverse.
defaults write com.apple.Safar i DebugUsePieProg ressIndicator -bool true
Ynt: MAC Terminal komutlar? ve kullan?m?
Cevap #2 - 26 Ekim 2010, 21:06
Haz?r yazm??ken bir de Türkçele?tirseydiniz ke?ke...
serhatakalin
Cevap #3 - 26 Ekim 2010, 22:52
Kusura bakmaky?n,hepsini türkçeye çevirip yazaca??m,
1.Dock 'u 3D sevmeyen kullan?c?lar için 2D Dock kullanmak isteyenler.Term inal penceresini aç?p :a?a??daki kodu yazarlar ise Dock 2 boyutlu olarak görüntülenir.
killall Dock
Cevap #4 - 26 Ekim 2010, 23:07
Ayr? ayr? yazmak yerine, mesaj?n?z? editleyerek çevirin isterseniz, sizin için de kolayl?k olur, okuyanlar için de :)
serhatakalin
Cevap #5 - 26 Ekim 2010, 23:16
Asl?nda bende öyle yapay?m diye dü?ündüm ama çeviri araçlar? çok anla??l?r ?ekilde çevirmiyor.Sizin bildi?iniz bir yöntem var ise yard?mc? olursan?z sevinirim.
Te?ekkürler.
serhatakalin
Cevap #6 - 26 Ekim 2010, 23:18
Bu arada Terminal network komutlar? elinizde var m? acaba,
Te?ekkür ederim.
tanic
  • Macbook pro 2011 i7 intel  8 Gb ram  120 OWC ssd
  • İleti: 256
Cevap #7 - 21 Ekim 2011, 17:34
arkadaslar terminal i sifirlamak mumkunmudur ?
yani girmis oldugum tum kodlari tum herseyi sifirlamak (silmek)
saygilar,,
macbook pro 2011 late
i7 intel quad core  8Gb ram  120 OWC ssd
iphone 4s 16 gb
ipod 5th gen 160 gb
Cevap #8 - 21 Ekim 2011, 17:35
Terminal'i kapatip acinca sifirlanmiyor mu?
tanic
  • İleti: 256
Cevap #9 - 21 Ekim 2011, 17:44
yanlis birseyler yaptim galiba, mac te yeniyim daha tam anlamiyla anlayamadim olup bitenleri,
sudo ile baslayan bir kod vardi onu girdim, mac te tuhaflasan birsey olmadi ama o girmis oldugum kodu silmek istiyorum, bunu nasil yapabilriim?
saygilar.,,,
iphone 4s 16 gb
ipod 5th gen 160 gb
Cevap #10 - 21 Ekim 2011, 17:56
Terminal DOS gibidir, bilmeden kurcalanmaz.
Kapat?p aç?n. Sudo sonundaki komut için admin hakk?n? açar, terminal kapan?nca biter.
tanic
  • İleti: 256
Cevap #11 - 21 Ekim 2011, 18:03
bir kac kere yazip kapattim yani suan korkulacak birsey yok degilmi ?
iphone 4s 16 gb
ipod 5th gen 160 gb
Cevap #12 - 24 Ekim 2011, 16:53
Yazd???n?z komuta ba?l?. Parola sorup yanl?? ?ifre girdiyseniz bir?ey olmaz. Ama sudo ile do?rulama yapt?r?p dock.app ile ilgili de?i?iklik yapan bir kod kulland?ysan?z ve ?ifreyi de do?ru girdiyseniz mesela, kod ne de?i?iklik yapt?r?caksa, yapm??t?r.
  • İleti: 407
Cevap #13 - 24 Ekim 2011, 18:17
yukar? ok tu?unu kullan?nca terminalde son girilen komutlar görülebilir. terminal geçmi?ini; home klasöründe bash_history ad?ndaki gizli bir dosyada saklar.
Terminali açt?ktan sonra (home dizinde oldu?unuzu varsay?yorum) "open .bash_history" yazarsan?z o dosyay? aç?p içeri?ini silip kaydedebilirsin iz.
ilhanu
  • ? iMac 27" i7 intel 3.4 Ghz 10.10
  • İleti: 29
Cevap #14 - 19 Şubat 2013, 15:50
Merhaba, internal masaüstünde duran bir Disk mount olmas?na ra?men gözükmüyor... Disk Utilty de görüyorum ama içine eri?emiyorum... Masa üstünde gözükmesi için terminalden bir komut verilebilir mi?
? ilhanU
